Home › Forums › Products › Stompboxes › H9 Control & MIDI CC for Knob 0 – 9 / Automating & Recording CCs
June 22, 2016 at 10:11 pm #113524
ReverendLove
ParticipantHi ladies and gents,
I want the H9 sending CCs to my DAW (Cubase 8.5 64 on Win 10) while I am controlling the pedal with H9 Control on my iPad Air 2 via Bluetooth.
But the only CC the MIDI input of my DAW see is the ribbon or the x/y pad as CC15. It is set up in CC XMT as CC15 as the knobs are configured to CC22-31.
If I move any knob (0-9) the pedal reacts correctly but doesn’t send any CC from its midi out. When I use the the ribbon on the control app everything works fine.
And if I use the big rotary knob to change one of the ten params the unit sends them to the DAW. Only if I try to use them on H9 Control they vanish in nirvana.
What am I missing?
July 6, 2016 at 5:14 pm #143761
ReverendLove
ParticipantAfter updating to the last firmware and new H9 Control this issue still exists. Is this normal? Intended? A failure of both devices? Or just a bug?
August 18, 2016 at 5:58 pm #144150
Imerkat
MemberReverendLove wrote:After updating to the last firmware and new H9 Control this issue still exists. Is this normal? Intended? A failure of both devices? Or just a bug?I want to give this a bump because i had the same question. I wanted the get the most MIDI capabilites out of the H9.
August 21, 2016 at 6:13 am #144159
stekfdd
ParticipantAlso this problem of MIDI CC outcoming from pedal to DAW…. DAW seen pedal, but not recieve CC comands. Only can send CC from DAW, but not from pedal to DAW..
September 15, 2016 at 1:06 pm #144395
ReverendLove
ParticipantI really wonder if this is such an exotic use case, that nobody cares for it.
October 7, 2016 at 2:15 am #144586
urbanjeram
MemberHi. Fresh one here.
I just bought the max version today, a mean dream machine. But…One of the most important reasons to buy it was the idea to play it on iPad and record automation to Live. I read somewhere else that Bluetooth and MIDI (also USB?) can’t coexist
daamnnn I hope I am wrong…
