H9 Control not finding TimeFactor
Home Forums Products Stompboxes H9 Control not finding TimeFactor
Viewing 5 reply threads
    • #112367
      The Eventide Direct Updater installed with H9 Control finds my TimeFactor and I can login and have already updated to 5.0.1.(3) without problem.
      However, when I launch H9 Control it tells me 'no Eventide device currently detected'. I have tried a restart, cables are good (as stated; direct updater worked fine). When I look at my account under settings in H9 Control, I seem to be logged in but no stompboxes are showing (my TF is already registered with Eventide ok..)
      What gives? All help appreciated! 🙂
    • #127568
      gkellum
        There's a section in the H9 Control user manual that deals with connectivity issues.  Just look under the section "Connecting to Devices":
        http://eventide.com/AudioDivision/Products/StompBoxes/H9ControlUG1.aspx
        This manual is also bundled into H9 Control under Settings / Help.
        If the user manual doesn't help, send an email to support describing what operating system you're on and whether the H9 appears under the Device Manager on Windows or Audio MIDI Setup on Mac.
      • #138343
        Will do & thanx for the fast reply.. Awesome!
      • #138345
        Will do and thanx for the quick reply.. Awesome!
      • #138348
        Oops.. Double post 😛
      • #138355
        All sorted out… I found the pedal as a usb midi device on the 'device not found – manually select a device' screen that opens when starting the H9 Control programme. Big Smile
