H9 controlling the EXP via midi
Home Forums Products Stompboxes H9 controlling the EXP via midi
Viewing 3 reply threads
    • #112115
      rdnzl
      Hi guys,
      I am sending CC values going from 0 to 126, and I am mapping this to EXP.
      The values on the pedal display only go from 20 to 94 though… any idea what is going on ?
      Kind Regards
    • #127069
      I'm guessing that at some time you connected an actual pedal and the unit autocalibrated to it. Now it is (wrongly) using the same settings. If this is so, it is a bug, but can probably be fixed by reinitializing the unit.
    • #127071
      rdnzl
      I tried to calibrate with 3 different pedals, but each time: 20 -> 94.
      I am a bit reluctant to reinitialise, as I have quite a few settings here and there (midi maps…).
    • #137683
      gkellum
      I believe if you just toggle the "Pedal Calibration Disabled" function from on to off and then to on again that it will delete your current expression pedal mapping. The system property I'm referring to —  "Pedal Calibration Disabled" — is under General Settings in H9 Control's Pedal settings screen. It might be named slightly differently on the H9 itself.
