Home › Forums › Products › Stompboxes › H9, Diatonic – problem
May 19, 2016 at 12:55 pm #113459
I can just achieve one “extra voice” in the diatonic algorithm. When I pan over to the “B-voice” only the original signal is heard, no harmony.
I´m plugged in to input1 and output1. What am I doing wrong?
May 19, 2016 at 1:39 pm #143397tenohr wrote:
I can just achieve one "extra voice" in the diatonic algorithm. When I pan over to the "B-voice" only the original signal is heard, no harmony.
A few questions:
– What version firmware are you running on your H9?
– Can you post a screen shot of your preset, or give us the parameter values?
– If you are on the later firmware, what is your routing mode?
May 20, 2016 at 7:01 am #143399
I have the latest software, and the normal routing. I have attached a picture of the preset.
To be sure, what is the actual version number of the H9 firmware you are running? You can find it in H9 Control by clicking on Pedal and looking in the top right hand corner (you need to be linked to your H9 of course). Also, just double check your connections, the H9 is backwards from the Factors, so I often get the I/O 1s and 2s confused.
So you're saying you only hear the -3rd voice, but not the Octave Up, correct? We can't duplicate this here. Do you have a similar problem with the Quadravox algorithm, or any other two voice algorithm like Digital Delay (or any TF delay for that matter)?
May 21, 2016 at 9:53 am #143410
Argh.. The output2 was connected after all. Disconnected and everything´s ok. Sorry for taking your time. And thanks!
Ha! Don't worry, happens to me more than I'd care to admit 🙂
