H9 does not show up in my Macbook bluetooth at all… cannot connect.
Home › Forums › Products › Stompboxes › H9 does not show up in my Macbook bluetooth at all… cannot connect.
Viewing 3 reply threads
    • #113810
      jaredrodgers
        H9 connects to my iphone just fine. Doesnt show up in my computer’s bluetooth menu at all.. I’ve reset everything many times. what else can I try?
      • #144855
        gkellum
          You reset your computer's Bluetooth?
          And your H9 isn't connected to your iPhone when you're trying to connect it to your computer?  You can toggle Bluetooth on the H9 off and on by pressing the X, Y, and Z switches simultaneously.
          If I were you, I'd probably try resetting the H9s system settings by turning it off and then turning it on again with the right footswitch and the HotKnob switch pressed (the switch in the upper left hand corner of the H9).  This will reset your system settings but won't affect your presets.
          I'd also move the H9 right next to the Macbook to make sure that too much distance isn't the problem.
          And if you're not powering it with the Eventide power supply, you should try it with the Eventide power supply.
          • #144858
            jaredrodgers
              gkellum wrote:
              You reset your computer’s Bluetooth?
              And your H9 isn’t connected to your iPhone when you’re trying to connect it to your computer?  You can toggle Bluetooth on the H9 off and on by pressing the X, Y, and Z switches simultaneously.
              If I were you, I’d probably try resetting the H9s system settings by turning it off and then turning it on again with the right footswitch and the HotKnob switch pressed (the switch in the upper left hand corner of the H9).  This will reset your system settings but won’t affect your presets.
              I’d also move the H9 right next to the Macbook to make sure that too much distance isn’t the problem.
              And if you’re not powering it with the Eventide power supply, you should try it with the Eventide power supply.
              Ok after resetting the system settings, restarting my mac, it finally connected…
            • #144859
              gkellum
                Great, thanks for letting us know that solved the problem for you.
            • #144863
              jaredrodgers
                Connected fine for a day or two. Now it says cannot connect…. Why do so many ppl have trouble with this??
              • #144864
                jaredrodgers
                  Excuse me, it says “there was an error connecting to the device”
                  • #144867
                    gkellum
                      jaredrodgers wrote:
                      Excuse me, it says "there was an error connecting to the device"
                      I see this happening on my Mac occasionally as well.  Normally, if I use the X, Y, and Z switches to toggle Bluetooth off and then on again, and try one or two more times, it will connect.  Once in a blue moon I'll have to reset the H9s system settings and/or restart the computer.
                      I'm not sure why this is.  I don't remember this happening in earlier versions of Mac OS, i.e. 10.9 and earlier.
