H9, Dual mono – turning off stereo
Home › Forums › Products › Stompboxes › H9, Dual mono – turning off stereo
    • #197146
      JohnnyAtmosphere
        Hello, I have a Dunlop volume pedal with dual mono out to two Mesa heads. I have an H9 and other effects on my board and I’m using it with the effects loops of both heads. H9 Input 1: Amp 1, Input 2: Amp 2. Output: 1 Amp 1, Output: 2 Amp 2. Often I’ll use the volume pedal in a 2nd mode, where I can pan back and forth between the two heads. So heel down Amp1, toe down Amp 2. The issue I’m having is if one these channels is silent (e.g. Amp2) the H9 will take the input from Amp 1 and then send it to Output 1 and Output 2, so Amp 1 is wet as desired, but Amp 2 which should be silent/dry is now wet and playing the stereo potion of the effect which is undesired. Is there a way to set the H9 so if one Input doesn’t have a signal it doesn’t receive the stereo output?   Thank you!
      • #198010
          Sorry, I’m not sure if what you are trying is possible, but your setup is not clear to me.
          What is the dual mono expression pedal you are using? I just did a quick search online and couldn’t find anything.
