H9 Expression with OBNE Expression Slider
Home › Forums › Products › Stompboxes › H9 Expression with OBNE Expression Slider
    • #164779
      palstatt
        I’ve got the Expression Slider from OBNE. When I use it with the H9 the expression curve is logarithmic for some reason. The first 50% of the slider is around 88% of the range with the remaining 12% spread over the last 50% of the slider. I haven’t seen this behavior on other pedals I’ve controlled with the slider. Is there a setting I can change to make it linear?
      • #164782
        joecozzi
          Hello palstatt,
          The OBNE expression slider uses a 100 Kiloohm potentiometer.  For best performance, Eventide recommends expression devices with 10 K – 50 K potentiometers. Using anything higher will cause the behavior you’re experiencing.
          • #164783
            palstatt
              Thanks for the response joecozzi. That makes sense.
          • #164794
            apalazzolo
              You could try putting a 100k resister in parallel with the slider.  That would bring the total resistance down to 50k Ohms.  It is not ideal but might be close enough.
