Home › Forums › Products › Stompboxes › H9 G2 – Not Connecting to Computer
- This topic has 19 replies, 6 voices, and was last updated 1 month, 2 weeks ago by
Grant Homann.
July 13, 2026 at 7:40 pm #196096
Just got the H9 Gen 2. This is my first Eventide product but I am familiar with other digital guitar pedals (HX Stomp, Walrus Mako Series, Morningstar MC6) and software in general. I am trying to run an update and connect my computer and phone with the H9 unit to edit algorithms. I have registered the device and downloaded the software but when I get to the Eventide Control launch page with the icons of your different pedals I come across a problem. The “add device” option opens up a drop down to select a port but it says “no choice” despite the fact that I am plugged into the device using the USB-C cable provided. It seems like there is something off here with the software–they just aren’t connecting. I have reset my computer and the H9 unit. Any tips?
July 14, 2026 at 10:52 am #196097
Sorry to hear you are having issues. Are you using Mac or Windows?
Are you using a USB hub or is the USB C connection going directly to your computer?
July 14, 2026 at 2:34 pm #196098
I am using Windows and tried with 1) the USB C cable that came with the H9, 2) USB to USB C, and 3) USB to USB C on another computer (with Norton uninstalled).
July 14, 2026 at 2:41 pm #196099
Thanks for the info. We will continue to troubleshoot the issue via the support ticket you opened.
July 18, 2026 at 5:40 pm #196117
I’m having the same issue, I can’t connect via BT or USB-C but i’m on MACOS 15 SIERRA. Pretty frustrating as I havent been able to really use this $600 brick right now.
July 20, 2026 at 9:58 am #196147
To clarify, Bluetooth is not yet available for this product. It will be available in a future update.
For your USB connection issue, your operating system is quite old and not supported by most modern apps. Eventide Control is officially support for macOS 10.14+ and we have not tested it with Sierra.
What exactly is happening when you try to connect to the pedal? Are you able to “add device” in the Eventide Control app?
Are you able to try a different computer with a more recent OS version?
July 20, 2026 at 3:35 pm #196164
I do not have another Mac at my disposal. I haven’t had any trouble connecting my original (white) H9 Harmonizer to my Mac by either bluetooth or usb-c.
As far as attempts to connect the H9 gen2 to my Mac; I’ve connected it via usb-c and powered on and H9 Connect simply won’t recognize it, I’ve also powered the H9 gen2 on and then connected it to the Mac, and it just doesn’t recognize it.
Although i’m running Sierra OS, I havent had any issues connecting my MIDI keyboard, synthesizers, external hard drive, hardware audio interface’s, or numerous other usb devices.
If I can’t get my Mac to recognize the H9 gen2 by any method, how would I ever be able to get the future update to enable the Bluetooth?!
Had I known bluetooth wasn’t immediately available, or wasn’t compatible with Sierra, I would’ve never purchased it!
I created a support ticket, and haven’t heard anything from them.
Unless you guys have a work around, I’m definitely thinking I need to return this thing
July 20, 2026 at 4:33 pm #196165
Thanks for the info, I just found your support ticket and we can troubleshoot the issue further there.
July 26, 2026 at 8:49 am #196326
I do not have another Mac at my disposal. I haven’t had any trouble connecting my original (white) H9 Harmonizer to my Mac by either bluetooth or usb-c. As far as attempts to connect the H9 gen2 to my Mac; I’ve connected it via usb-c and powered on and H9 Connect simply won’t recognize it, I’ve also powered the H9 gen2 on and then connected it to the Mac, and it just doesn’t recognize it. Although i’m running Sierra OS, I havent had any issues connecting my MIDI keyboard, synthesizers, external hard drive, hardware audio interface’s, or numerous other usb devices. If I can’t get my Mac to recognize the H9 gen2 by any method, how would I ever be able to get the future update to enable the Bluetooth?! Had I known bluetooth wasn’t immediately available, or wasn’t compatible with Sierra, I would’ve never purchased it! I created a support ticket, and haven’t heard anything from them. Unless you guys have a work around, I’m definitely thinking I need to return this thing
did you manage to get this sorted? I’m having the same issue, unable to connect either with my MacBook Pro, or an M1 iPad Pro.
July 27, 2026 at 11:39 am #196431
Update: I got it to work. I had downloaded the wrong app (H9 Control). The correct app is Eventide Control.
July 27, 2026 at 12:04 pm #196435
Glad to hear you got the connection to work!
August 12, 2026 at 10:21 am #197089
Hi, I am having the same issue as JSinger42 who doesn’t seem to have an answer yet (or did you get it to work.
Just purchased. About an hour away from returning it
August 12, 2026 at 5:57 pm #197101
Figured mine out. Had to uninstall the USB port from Device manager and let Windows refind it and re-install it. All set
October 9, 2026 at 6:51 am #203868
Hi help windows 11 pc not recognising H9 gen 2 in Eventide control software so I can’t update, just got this pedal and to be quite frank it should not be this difficult seems like it was released before it was ready,
October 9, 2026 at 8:19 am #203881
Sorry to hear this!
Can you please be more specific about the issue?
When you click “Add Device” does the pedal show up as a device to be added?
Are you using the USB cable that shipped with the pedal?
October 9, 2026 at 10:03 am #203890
Hi no is does not show up on the add device menu
October 9, 2026 at 12:01 pm #203893
Thanks for the information.
Can you please try a different cable and confirm that the pedal is connected directly to your computer without a USB hub?
If you have Norton Antivirus software installed, please try disabling Norton’s SafeCam setting and checking if the issue persists.
October 9, 2026 at 10:06 am #203891
Hi no is does not show up on the add device menu yes I’m using the provided usb cable
October 9, 2026 at 10:38 am #203892
Hi Grant, I have had the same frustrations with the product that you are currently experiencing now. Feel free to reach out to me with other frustrations after you get this one solved as I may have already been through them.
As far as the connection, I could have swore I was using the provided usb-c cable but in fact, I wasn’t. Not all usb cables are equal. Once I connected the right cable, usb-c/usb-c and not an Amazon Basics one, I was in business. I mention this only because I would have bet anything I was using the provided cable and I wasn’t. I have found other cables to work but usb/usb-c cables will not for sure.
After that I would try different usb-c ports on your computer if you have them available, or reboot with the H9 attached.
October 9, 2026 at 1:24 pm #203907
No luck
correct cable supplied one
direct connection
checked cable with iPhone
turned off Norton
windows 11
restarted everything etc
