H9 Gen 2 (H90) Preset List (Single & Double Whammys)
Home › Forums › Products › Stompboxes › H9 Gen 2 (H90) Preset List (Single & Double Whammys)
    • #200651
        99 PolyFlex presets, *.lst9 file, set up for Bank Mode.  Two selectable pitch shifts per preset, with the same controls & concepts used throughout.  Importable into an H90 Program List as preset (01-99) in Series with Thru.
        • Naming convention geared to the Bank screen crawler.
        • (Bend) label = 100% wet.  (Mix) label = 50:50 dry / wet.
        • EXP1 – Manual Flex A & B.  HotKnob – Flex Time & Return Time.
        • AUX 1,2,3 – all momentary (HS1 – HS2 – FLEX DUAL).
        • PERFORM p.1 – Active / Bypass & FLEX DUAL [L].
        • PERFORM p.2 – HS1 [L] & HS2 [L] (default saved page).
        • EXP1 and/or FLEX DUAL controls the active pitch shift(s).
        • Select Preset pairing with Bank navigation.
        • Base preset uses both A & B pitch shifts.
        • Select either pitch shift extent with HotSwitches.
        • Most (not all) presets: saved with HS2 (Voice B) ON as default.
        Posted first at TGP, with some minimal added background.  I’ll admit to having some paranoia here about angering the spam bot filters.  There have been times when my topics & replies have been ghosted by using a lot of links & attachments.  But this is the most appropriate spot for the new cross-compatibility aspects, so here goes …
      • #200668
          The Preset List attachment in the OP got nuked (twice), so maybe an unsupported file type, or an aggressive protection scheme.  Not a complaint, as the trolling & spam posts got way out of control here at one point.
          Let’s try using a direct link, so the topic I initiated makes some sense:
          Single & Double Whammys – H9 Gen 2 (H90) Preset List
