H9 Gen 2 – How to use MIDI to control Diatonic Learn?
Home › Forums › Products › Stompboxes › H9 Gen 2 – How to use MIDI to control Diatonic Learn?
    • #208075
      andychar
        I’d like to use MIDI to trigger the learn function so I can set the key in real time, but “Learn” is not a parameter that is shown in the onboard parameters or in Eventide Control.
      • #208076
          If you click the “Controls” tab in the top, you can find the Learn function under Performance Parameter Mapping.
          Select the “Learn” Performance Parameter and then choose your MIDI CC for the control source.
          Let me know if you need further assistance.
          Screenshot 2026-11-25 at 7.58.45 AM
        • #208110
          andychar
            Thank you, that worked great…I have a request.
            On the H90, if you use Learn via MIDI control, the detected key flashes on the screen as it learns.  This does not occur if you use Learn via any other type of switch (built-in, aux etc.).
            On the H9G2 it never happens under any circumstances.  It would be useful to have that feedback on the H90 as well as H9G2.  Thanks!
