H9 Gen 2 mode cycle
Home › Forums › Products › Stompboxes › H9 Gen 2 mode cycle
    • #200204
      Echo-Plex
        I know there’s separate midi messages for select, bank and perform modes, but is there a midi command that can cycle between these 3 modes? For example using one foot switch on a midi device to cycle between these 3 modes.
        thanks
      • #200216
        Echo-Plex
          Just to update, i wrongly assumed there were midi messages already pre programmed, but there don’t seem to be any CC or PC already in the unit?
        • #200329
            You are correct, there are no default MIDI mappings. You must configure any MIDI mappings for your particular setup.
            There is a Global MIDI mapping to toggle between Select and Perform Mode. Note that this does not cycle between all 3 modes, it will cycle between either Select / Perform or Bank / Perform. You’ll need to choose either Select or Bank mode first using the Pedal UI, or using the MIDI command to choose Select / Bank mode.
            Let me know if you have any questions.
            https://cdn.eventideaudio.com/manuals/h9/1.2.2/en/content/appendix/global.html
