H9 Gen 2 – Tuner
Home › Forums › Products › Stompboxes › H9 Gen 2 – Tuner
Viewing 3 reply threads
    • #196076
      Richard_UK
        In the user manual it says to press and hold the Left and Right Footswitches together while in Select Mode to access the tuner.
        I have tried this multiple times and holding the footswitches for different lengths of time, but the tuner never appears.
        Is there some setting that I might have changed that might be preventing the tuner from appearing?
        All other functions of the pedal appear to be working correctly.
      • #196077
        c_joules
          I am having the same issue. I’ve attempted the process numerous times and nothing happens?
        • #196078
          Richard_UK
            My H9 Gen 2 came with software version 1.0.1.85.
            I have just installed the Eventide Control app on my MacBook Pro and connected the H9 via USB. The app said a software update was required. When the update completed the H9 was running version 1.1.7.135.
            And now the Tuner does appear when I press and hold both footswitches for a few seconds.
          • #196083
              Glad to hear you resolved the issue.
              That is correct, you must update the firmware to 1.1.7 to unlock the tuner.
