h9 harmodulator bug ?
Home Forums Products Stompboxes h9 harmodulator bug ?
Viewing 7 reply threads
    • #111459
      rdnzl
        Hi guys,
        I am using this effect to detune my bass a step down. Now, the effect will detune a lot more that one step, by itself, for a few seconds, and come back, erratically, to what I have set it.
        I am not sending any midi to it, it just happens… any idea what might be going on?
        Cheers
        Laurent
      • #125566
        badmelonfarmer
          Do you have the modulation set to sweep down?
          i would try setting everything to a neutral/ unison / off position then turn the pitch to be a step down to see if you still get it…. But it sounds like the modulation parameter to me if it is a sweeping sound rather than fixed interval.
        • #125568
          rdnzl
            It's actually not a sweep, it plunges super low for a while and surfaces back to normal after a few seconds…
            In fact, I can achieve the same effect, reliably, with microPitch, so I am okay…
            Cheers
          • #136367
            rdnzl
              Hi guys
              It happened again yesterday, during a gig…
              At home, it always work lime a charm… could it be the power supply that is making the this erratic behaviour? It is as if the envelop setting was playing up…
              Thanks
            • #125644
              h9controller
                Hi Laurent,
                Did you try setting your input source to BASS in the H9 System Settings?  As well, the PITCHFLEX algorithm might be another option for you.
              • #136391
                wedelich
                  Hi rdnzl,
                  Will you tell us all the knob values on your preset that has this problem, as well as expression pedal settings?  I think that might be a good starting place.  To me it really does sound like the modulation is set to Square wave, and the depth is set to some negative interval.  Either that or the expression pedal is mapped to do this drop and something (possible bug) is triggering expression pedal somehow.  But we really need more info about you settings and setup to help diagnose the problem.
                  Thanks
                • #136405
                  rdnzl
                    Here we go:
                    Mix: 100
                    Pitch Mix: A0 +B10
                    PitchA:-m2
                    PitchB:+m2
                    DelayA:0ms
                    DelayB:0ms
                    Tempo Off
                    Mod Depth:-2Oct
                    Mod Sens: 0
                    Shape Envelope
                    Feedback 0
                    Now, I realise that my source was on SynthBass… that might be the reason why…
                    Cheers
                    Laurent
                  • #136413
                    wedelich
                      It might be possible that with Mod Sens set to 0 you could still randomly trigger the modulation (depending on how hot the input signal is).  I would change Mod Depth to 0 as well just to be sure.  Try that and see if it fixes your problem.
