H9, Mastermind PBC 6x, Suhr Min Mix II and Conversion
Home Forums Products Stompboxes H9, Mastermind PBC 6x, Suhr Min Mix II and Conversion
Viewing 0 reply threads
    • #163457
      JavyMontoya
        I recently got an H9 Max and it eliminated 4 stompboxes from my board hence going from a 26×14 Vertex to a 20×11. AMAZING! I love the unit.
        I’m running the H9 in Pre/Post mode with the “Post” Presets in Kill Dry going through the Mini Mix II and back into the Mastermind loop 6.
        Then I run the “Pre” Presets without Kill Dry straight into the Mastermind loop 3.
        For my understanding, can someone please help me understand how using Pre/Post mode uses two conversions and what that may be doing to my signal path with this set-up?
        Does Output 1 and/or Output 2 now have two conversions instead of one? Do my “Pre” presets have twice the latency?
        It would be helpful to know what’s happening at the routing level.
        Thank you!
