H9 Max Out – second unit
Home Forums Products Stompboxes H9 Max Out – second unit
    • #115145
      denislachance
        Hi, is it possible to max out a second unit ? I understand that I can share my algorithms on my Max to allow my core to use them. Now if I load an algo on my core with the apps ( iOS or PC) it works fine. If I don’t use apps, can I load the algorithm on my core ? Or do I have to buy it in order to use it ? The 2 units aren’t talking together directly. They need to be linked through the apps.
        Thanks to confirm for a second max out…!
      • #150962
        bohan
          denislachance wrote:
          Hi, is it possible to max out a second unit? I understand that I can share my algorithms on my Max to allow my core to use them. Now if I load an algo on my core with the apps ( iOS or PC) it works fine. If I don’t use apps, can I load the algorithm on my core? Or do I have to buy it in order to use it? The 2 units aren’t talking together directly. They need to be linked through the apps. Thanks to confirm for a second max out…!
          If you can load it on the app, you can load it on the unit as well. Have you tried saving a preset to the CORE? Or scrolling algorithms by pressing PRESETS button twice and turning the encoder?
