H9 MAX sharing algorithm system
Home Forums Products Stompboxes H9 MAX sharing algorithm system
  • This topic has 3 replies, 2 voices, and was last updated 4 years ago by tktk.
Viewing 3 reply threads
    • #162629
      tktk
        When you buy a used H9 MAX, what would happen if the previous owner of the MAX (deregistered it from his account) kept algorithms off it installed to his other H9 COREs?
        Would the new owner of the MAX still be able to share algorithms with his up to other 4 COREs?
        Thanks in advance.
      • #162633
        joecozzi
          Yes. All that matters to Eventide is that the serial number does not belong to anyone else. The new user will be able to “activate” up to 4 more core/standard units.
        • #162634
          joecozzi
            The old user, however, would run into problems when they tried to use H9 Control. The system would detect that a Max is no longer registered to their account and revert them back to Core units inside the app.
          • #162635
            tktk
              Understood. Thanks for the clarification.
