H9 Maxout bundle, multiple issues after upgrade
Home › Forums › Products › Stompboxes › H9 Maxout bundle, multiple issues after upgrade
Viewing 9 reply threads
    • #116282
      gerax
        Hi all,
        I just purchased the upgrade from my H9 Core to the Max bundle as per the promotion.
        Now, looks like even though I can see all the algorithms in my H9 Control app account, I can’t get therm to work with the pedal.
        I tried to sync the pedal with the server, and it says the purchases were restored, but I cannot update the pedal’s software, the installation gets stuck no matter what version of the software I try to install (it’s currently on 4.8.0.1), and no matter what connection I use (either Bluetooth or USB cable).
        The pedal starts the process but gets stuck halfway when the “clearing the cache” appears. I get a connection error, but the pedal is connected via USB cable and not moved throughout update.
        Nice right?
        Then comes the DAW plug-ins part which I downloaded and installed but whose activation via iLok account is not working even though I submitted it right after the purchase to my iLok account…(I’ll post about this in the plug in s forum).
        Definitely a frustrating situation and a less than smooth experience with this upgrade, considering the cost of the purchase…
        Any help is welcome.
      • #156760
        joecozzi
          Let’s start with the pedal. Are there any other cables connected to the H9 other than the USB cable and the power adapter when updating using your computer?
        • #156762
          joecozzi
            Ok, try this. Back up any custom presets you have on the pedal to a list. Then, conduct a factory reset of the pedal by holding down the right footswitch and big black encoder simultaneously while power cycling the pedal. The words [INITIA] should pop up. Then, try the firmware update again.
          • #156763
            joecozzi
              Also, make sure you have the latest version of H9 Control installed on your computer.
            • #156765
              gerax
                Here’s what I’m getting:
              • #156766
                joecozzi
                  Try one more thing, download and install the Eventide Device Manager: https://www.eventideaudio.com/support/product/14079/installers
                  Then, power up your H9 while pressing and holding the HOTKNOB button to boot in UPDATE mode
. Click “Search for device” in Direct Updater, select the latest software and update your H9
. Wait patiently until it finishes and H9 will restart.
                  Let me know if this works.
                • #156768
                  bohan
                    Ah, Joe just posted another solution! You can try either one. They work the same way.
                  • #156769
                    gerax
                      Looks like that worked! A strange thing happened towards the end of the writing part, as the display on the pedal red “READY” and then “BAD”, and I also got an error message on the updater, but then the pedal restarted and it now shows the current FW version reading 5.8.5[1].
                      Ideas?
                    • #156771
                      joecozzi
                        Now with regards to the plug-ins, you say you downloaded and installed them. Did you go into the ilok license manager software and activate the license by moving it to the computer you're using or an ilok key, if you have one?
                      • #156778
                        joecozzi
                          Email support@eventide.com along with your proof of purchase and they should be able to deposit the license into your iLok account for you.
                        • #156761
                          gerax
                            Hi, thanx for the reply.
                            No, there are no cables plugged ion except power (from a Pedal Power) and USB.
                          • #156764
                            gerax
                              I just did, the factory reset worked but the FW update gets stuck no matter what. I have the presets backed up on the iOS app so I can try it again if you think that can yield any result. I have downloaded and installed the H9 Control MacOS app available on the Download section (it reads 3.7 on the install volume).
                            • #156767
                              bohan
                                Have you tried reinstalling your H9's firmware in the UPDATE mode with the Direct Updater? The Direct Updater is bundled with H9 Control. You can find it by clicking "Window" -> "Open Eventide Direct Updater" in the menu bar of the H9 Control. H9 needs to be booted in the UPDATE mode to be updated by pressing and holding the HOTKNOB button when powering it up.
                              • #156770
                                bohan
                                  gerax wrote:
                                  Looks like that worked! A strange thing happened towards the end of the writing part, as the display on the pedal red "READY" and then "BAD", and I also got an error message on the updater, but then the pedal restarted and it now shows the current FW version reading 5.8.5[1].
                                  Ideas?
                                  Hard to diagnose just by that. What error message did you see in the Direct Updater?
                                  If you can use your pedal normally and the connect to it without any problems, then it should be good.
                                • #156774
                                  gerax
                                    bohan wrote:
                                    Ideas?
                                    I’ll hook it up ton the rest of the rig and check that out.
                                  • #156775
                                    gerax
                                      joecozzi wrote:
                                      Now with regards to the plug-ins, you say you downloaded and installed them. Did you go into the ilok license manager software and activate the license by moving it to the computer you’re using or an ilok key, if you have one?
                                      Well, part of my licenses are on a physical iLok key, part (like the Apogee Bundle) are on the cloud version, but the thing is, I didn’t get any license on my iLok account, so i cannot transfer anything to the iLok Manager on my MacBook Pro.
                                      I did click the “Submit” button after the purchase, and the iLok account name is correct. Any ideas here?
                                    • #156780
                                      gerax
                                        I will, thank you for the help so far.
                                        Best
                                        L.
