Home › Forums › Products › Stompboxes › h9 midi control in cubase ?
October 24, 2017 at 1:50 am #114435
hi Guys.
I have a small problem. I try to control my h9 per midi in cubase 8.5. how can I do this ???I have not done it before. I have tried. assign midi cc messanges receive map to make the assignments. and the dan also in cubase but it will not go
October 24, 2017 at 7:11 am #147490
I run Cubase, too.. so maybe I can help you.
First- please tell us EXACTLY how you have things set up, and what you are trying to do!
October 24, 2017 at 2:33 pm #147492ok sorryI am trying to control my h9 via cubase8.5, so for example …. active and bypass, and controle oll the parameter, per midi in a automation.I am in cubase a midi track and wele since the h9 out in in and output … the signal goes to channel 1 through my rme fireface uc in the input of h9 …… I tried channel 1 and the but it does not work I have tried several kanele and also assign in the h9 but without success
October 25, 2017 at 5:19 am #147500
ok.. this sounds like it should work.
Cubase is sending CCs
H9 setup to recieve CCs
Midi connections all correct.
Do you have any OTHER midi devices you can test with?
Have you controlled the H9 via Midi any OTHER way?
October 25, 2017 at 2:38 pm #147501
so ok ….and i am ride wenn make the cc ruting in assingn midi cc messages to pedal function ther i make my ruting s,,,,,, end is the set parameter 1 -10 is for my for example /wet mix and delay filer nobs in the h9 is this ride
October 25, 2017 at 2:38 pm #147502
October 26, 2017 at 12:14 am #147505
Yeah, thats right. The “Parameters” refer to the 10 knobs on each preset.
October 26, 2017 at 7:11 am #147510
ok ….and kann i us it wit usb and midi??? ….and i must ruting the paramiter ??? cc in the h9 ? it stress my so hard hahaha =/
October 27, 2017 at 12:58 am #147516
It IS hard.
What is your native language? Maybe someone here speaks it, and they can help more effectively.
October 28, 2017 at 9:14 am #147532
I am German
October 29, 2017 at 3:01 am #147534
I would hit up the Cubase forum with this for sure then. They have a robust german-language forum!
November 2, 2017 at 8:17 am #147576
i have no clu way but now is working …i have still e conekting problem with my computer but midi is working so my problem is donn for e wile …thx too you bro
