H9 on pedal board
Home › Forums › Products › Stompboxes › H9 on pedal board
Viewing 9 reply threads
    • #111869
      kenhan
        I just received my H9 Friday. Very excited to explore and learn all it has to offer.
        I'm now considering how to put it on my pedalboard. I hate velcro and there's really no good way to use zip tie for H9 with no much free space on the face for the zip tie to run across. One possible scenario I've been considering is removing 2 of the screws on the bottom, find replacement thumbscrews to screw through the pedalboard.
        Can one of the H9 engineers / designers comment on what the screw dimensions are, thickness, thread count, etc? Sometimes you can force fit a screw that doesn't quite fit, and I'd like to avoid it. Thanks.
      • #126577
        achaput
          The "Industrial Strength" velcro that Home Depot sells  is very strong and works well. Have you tried it?
        • #126579
          kenhan
            No I haven't tried it. My dislike of Velcro is not about its ability to secure the pedal, which I think Velcro does well enough. It's more about leaving permanent marks with the adhesive. I'm attracted to the idea of thumbscrew because it will le me secure the pedal with, be able to remove without tools, and leave nothing behind on the pedal.
          • #137235
            achaput
              Ahh, I see. Well 3 mm screws should do the job.
            • #137238
              kenhan
                Thanks. And the thread count?
              • #137245
                tsternfeld
                  The screws are, as Alan said, M3 with an 0.5mm pitch.   The ones we use are 8mm long, but you'll cclearly want something longer depending on what you're attaching to.
                • #137260
                  camilok
                    Get a piece of clear plexiglass and cut it to the shape of the bottom.  Get screws that are longer by the width of the plexi, and attach the velcro to the plexi.
                  • #137262
                    kenhan
                      camilok:
                      Maybe I'm missing something, but why? That just sounds like twice the work and twice the cost for no discernible benefit.
                    • #137263
                      camilok
                        The use of the screw-attached plexi mitigates your fear of marring the pedal with adhesive.  This technique is also very effective on wah or other large format pedals.  Mission even sells kits for their pedals with plexiglass and larger screws.
                        I got a large piece, 2 x 4 feet at the hardware store for just a few bucks.  cutting it out takes literally 30 seconds.
                        I used this on my prized BK butler pedal – I did not want his autograph on the bottom being marred by the adhesive;  this way I can still read the bottom, and have a place to attach the velcro in a non-destructive manner.
                      • #137265
                        kenhan
                          Thanks for the input camilok!
