H9 pre/post problem
Home Forums Products Stompboxes H9 pre/post problem
Viewing 3 reply threads
    • #114644
      MPhase4
        recently I started to using theH9 in pre/pos routing to add the super great PichFuzz algo. to use.
        Now unfortuately the following problem occurs.
        If I switch from a post-preset (hall, delay….) to pre-preset (fuzz, crush….) I have a short loud chirping noise out of the speaker.
        Is there any way to prevent that?
      • #148625
        camn
          I have the same, I think.
          To the extent that I rarely go pre-post or post-pre in the same song if I can help it.
          I imagine it is unavoidable, with the actual physical jack-switching.
        • #148627
            Switching any audio signal will have an effect. On the pre/post there are crossfades on the switching, which helps, but you may still get a bump on the sound.
            In general, you should try to never change routing or load presets with signal passing through a system. Any system.
            That said, the "chirp" he describes suggests there may be some kind of feedback present, which is easy to get with a pre/post system. I would suggest experimenting with the wiring and the grounding – this may be a factor.
          • #148650
            bansta
              Solution: I use Boss ES5 before the amp: H9_PRE is in the loop 5 of Boss, H9_POST is in the amp’s effects loop.
