Home › Forums › Products › Stompboxes › H9 Pre/Post relay bypass
June 8, 2018 at 11:57 am #114778
Not sure if it has been answered already, but when using relay bypass with pre/post routing is it still actually in relay mode? or because the pre post mixing is happening in the dsp the signal has to be converted?
Thanks. -
June 8, 2018 at 3:14 pm #149445nati.taub wrote:Not sure if it has been answered already, but when using relay bypass with pre/post routing is it still actually in relay mode? or because the pre/post mixing is happening in the DSP the signal has to be converted? Thanks.
DSP bypass is used in Pre/Post routing mode regardless of what the bypass setting is.
June 8, 2018 at 4:11 pm #149448
So why is the dry signal changes when I flip between the bypass modes?
June 8, 2018 at 6:06 pm #149450nati.taub wrote:So why is the dry signal changes when I flip between the bypass modes?
I was wrong…You are right. You can still choose which kind of bypass to use in Pre/Post mode.
June 9, 2018 at 2:09 pm #149457
so it does keeps the relay bypass in pre/post routing? you got me confused 🙂
I'm sorry for confusing you…Yes, if your bypass mode is set to Relay. The bypass mode in pre/post routing is same as normal routing. You may set the bypass mode to DSP, Relay, or DSP+FX (effect tail).
