H9 questions. Seriously considering purchase soon. Really
Home Forums Products Stompboxes H9 questions. Seriously considering purchase soon. Really
    • #115454
      I’ve been a TC GMajor 2 user for a very long time. I run it in the FX Loop of my Bogner XTC
      I control the GMajor with a Rocktron All Access, run in stop box mode. Basically, there are three rows of 5 switches. The bottom 10 select Patch changes, and the top 5 allow me the ability to turn individual FX’s on or off. Those switches are set globally, so #1 is always reverb, two is delay etc.. When I select a patch, the All Access determines if the FX is on or off per preset.
      In the GMajor, each patch’s output volume is adjustable, from zero backward. This allows me to have a volume boost for solos, by having gain reduction on the non solo patches. Simply reducing the output by 4-5db works.
      *Can I set up the same type of functionality with the H9?
      *In each Patch, are multiple FX active? Chorus, reverb and delay on the same patch for example?
      *If so, can I remotely turn the Individual FX’s on and off with the All Access without changing the patch using MIDI CC?
      If what I learned on YouTube is correct, I can reduce the output gain of each patch. Is that correct? This allows me to have a patch or two with no gain reduction effectively acting as a solo boost. This works quite well.
      Thanks for any help.
      Bob
    • #152461
      bohan
        Basically, yes,
        You can only use 1 algorithm on H9 at a time. However, there are some algrithms with multiple effects, like SpaceTime and PitchFuzz. Please see demo videos for more details:
        https://www.youtube.com/watch?v=rDPKqUVhjzo
        https://www.youtube.com/watch?v=HDCURROB8P0
        Yes, each parameter in H9 can be remotely controlled by MIDI CC messages
        Yes
