H9 Screen Starts to Flicker After a While
Home Forums Products Stompboxes H9 Screen Starts to Flicker After a While
    • #116402
      BassPorn
        Hello, Everyone…
        I tried to search the forum for this topic, but with no luck…
        My eventide H9’s onBoard screen starts to flicker after a while (not long, actually)…
        It does so for a bit, then the letters begin to scroll… then they light one by one… then…
        It is hardly usable in these conditions…
        Any thoughts as to what this could be and how to fix it?!?…
        Grateful to anyone who might land a hand…  Cheers…
        Pier
      • #157445
        bohan
          BassPorn wrote:
          Hello, Everyone…
          My eventide H9's onBoard screen starts to flicker after a while (not long, actually)…
          Pier
          Are the effects are good? And does H9 Control work without any issues? If so, it may be a connection issue between the display and the board.
        • #157446
          BassPorn
            Hello, Bohan…  Thanks for your quick reply…
            No, unfortunately it’s not just the display: as this happens, the sound becomes progressively degraded and disappears in the end…
            Pier
          • #157447
            bohan
              No, unfortunately it's not just the display: as this happens, the sound becomes progressively degraded and disappears in the end…
              Pier
              OK. You may try
              1. Reinstalling its firmware by using the Direct Updater, which is bundled within H9 Control. It can be found if you click "Window" -> "Open Eventide Direct Updater" in H9 Control's menu bar on Mac, or by searching "Direct Updater" on Windows's start menu. You'll need to boot UPDATE mode by powering up the unit with HOTKNOB button pressed and held to do the update.
              2. After update, try a factory reset by powering up the unit with the right footswitch and the black encoder knob pressed.
              If these don't fix the issue, you should email support@eventide.com and consider to send it in for repair.
            • #157450
              BassPorn
                bohan wrote:
                OK. You may try
                1. Reinstalling its firmware by using the Direct Updater, which is bundled within H9 Control. It can be found if you click “Window” -> “Open Eventide Direct Updater” in H9 Control’s menu bar on Mac, or by searching “Direct Updater” on Windows’s start menu. You’ll need to boot UPDATE mode by powering up the unit with HOTKNOB button pressed and held to do the update.
                If these don’t fix the issue, you should email support@eventide.com and consider to send it in for repair.
                Hey, Bohan…  Thanks for your precious suggestion…
                Unfortunately, Direct Updater does not appear to be able to communicate with the H9, even over a direct USB cable…
                Guess I should open a ticket?!?  (do consider I live in Italy)…
                Pier
              • #157456
                bohan
                  Pier
                  If and factory reset doesn't work and your PC/Mac cannot recognize your H9 as a USB or MIDI device, you should probably get it repaired. Please contact the seller or email support@eventide.com
                • #157462
                  BassPorn
                    bohan wrote:
                    If and factory reset doesn’t work and your PC/Mac cannot recognize your H9 as a USB or MIDI device, you should probably get it repaired. Please contact the seller or email support@eventide.com
                    Thanks, again…  I’m afraid I’m gonna have to do just that…
                    All my best…  Cheers…
                    Pier
