H9 stereo out?
Home › Forums › Products › Stompboxes › H9 stereo out?
    • #180377
      merula
        My H9 does output stereo on something like a ping pong delay but doesn’t seem to on others. For instance, using PitchFactor Diatonic I am setting a 3rd and a 5th but only hearing one of these intervals. I’ve played with all the parameters and mix levels. When I unplug one of the outputs there is no signal on one side. Cables all tested and it seems output works on other algorithms. What is happening?
      • #180385
        joecozzi
          Hi merula,
          In an algorithm like Diatonic, the Pitch Mix parameter serves to adjust the level of each voice relative to each other. When the H9 is connected in stereo each voice gets panned to one side. For equal volume for each tap, the Pitch Mix parameter should be in the middle where it says A10+B10. If you have it fully clockwise, for example, you will only hear one voice, the B voice that is panned to the right. This could be what you are experiencing because disconnecting either output will only render the B voice if Pitch Mix is “all the way up” instead of in the middle. Can you check that setting?
