H9 stopped receiving MIDI signals through DIN5.
Home Forums Products Stompboxes H9 stopped receiving MIDI signals through DIN5.
    • #115531
      cljfford
        My FX-Loop H9 has stopped responding to MIDI signals.
        Am I missing something? What can I do to wake up it’s DIN5 ears?
        The MIDI signal  is from a Keith MacMillan Softstep2 to a SoftStep Expander, into the preamp H9. The settings are below. I swapped out the MIDI cable between the H9s with no success and went from the Expander directly to the FX-Loop H9 “in”, but still got no result with the FX-Loop H9. Pre-Amp H9 receives the DIN5 signal normally. The FX-Loop H9 responds fine via bluetooth but not via DIN5.
        My settings used to work. I confirmed that the SoftStep was sending signals to Channels 1 and 2.
        Preamp H9 MIDI Settings
        • Receive Channel= 1
        • MIDI Output Mode= Thru + MIDI Clock
        FX-Loop H9 MIDI Settings
        • Receive Channel= 2
        • MIDI Output Mode= Transmit
        Thank you.
      • #152801
          Make sure that the USB cable is not connected to the H9 – it can only use ONE of USB or DIN, and if the USB is connected it will not read DIN.
        • #152815
          camn
            something I think it is worth doing troubleshooting MIDI problems- Hook up your SoftStep to a computer, and look with MIDIOx or something to see what signals/channels are being transmitted. For confirmation.
            So many times it is the sending device that got changed or something. But you don’t have to speculate.. you can know.
          • #152809
            cljfford
              Thanks, nickrose, for that advice, but no USB is connected.
              Regular power cycling has not solved the issue. Would a factory reset be worth a try?
            • #152814
                It's always worth a try, but can be annoying as you have to redo all your settings.
              • #152831
                cljfford
                  nickrose wrote:
                  It’s always worth a try, but can be annoying as you have to redo all your settings.
                  The factory reset got it working, again, I am happy to report!
                • #152832
                  cljfford
                    Thanks for this contribution. I checked out http://www.midiox.com but I’m on Mac OSX, so it’s not a fit, but maybe there’s something like it? I wound up trying a factory reset and that worked, so I’ll save the troubleshooting for when there’s trouble. wink
