[H9] Tap subdivisions with expression pedal?
Home › Forums › Products › Stompboxes › [H9] Tap subdivisions with expression pedal?
Viewing 4 reply threads
    • #114817
      I use my H9 with bass and I’d like to reproduce the choppy bass you hear on dubstep records or Nerve music (think John Davis bass tones). I came to the conclusion that you can get that sound using a tremolo and a combination of different tap subdivisions.
      Is there a way to configure an expression pedal to go from quarters to triplets to dottet eights etc.?
      A suggestion on which algorithm to choose would be great too.
      Thanks.
    • #149638
      mistercharlie
        This sounds like a job for Ultratap. Try assigning to the expression pedal to Spread, and maybe also Taps.
      • #149659
        Thanks.
      • #149665
          Adding to mistercharlie‘s suggestion:  CHOP is a useful UltraTap parameter, and its SPEED can be mapped to an expression pedal.  Here’s one example, that you can modify to fit your needs:
          https://www.eventideaudio.com/community/presets/brock/slowgear-tremolo
          That said, the same can be done in other algorithms, like TremoloPan or TremoloVerb.  Maybe even the Undulator algo.  Of course, TEMPO should be ON, in any case.
        • #149670
