H9 thru GCX and GROUND CONTROL
Home › Forums › Products › Stompboxes › H9 thru GCX and GROUND CONTROL
Viewing 0 reply threads
    • #111346
      charlyrey
        hi…..I m using my h9 thru the GCX and the ground control via MIDI…..I m accesing all the MIDI parameters via the EV 5 connected thru the ground control….everything works perfectly…only one thing  don t work or I m probably missing something…..when I m using the pitchfactor algorithms as a whammy it seems to have a little bit of delay to hit the higher note…..also when I have to switch it on pressing the EV5 ( toe down on the ev5 ..no fx….toe up fx on)…..
        I thought that it was cause I was controling the fx thru the ipad…..but when I use it without it (the fx s are in the stompbox) it still happens……I try changing the parameters….the H-T GLISS is in 0.01 s…
        ..with no luck……what can I do?
        thanks
