H9 Tremolo not holding up with BPM
Home Forums Products Stompboxes H9 Tremolo not holding up with BPM
    • #114608
      Euji
        Hi folks,
        I’m having an issue with my H9, specifically with the Tremolo/Pan algo running.
        I need the trem to work as a “slicer”, set at 1/16 note. My H9 is hooked up to a MusicomLab MKV which is sending tempo via MIDI to the unit. I tried different solutions, even storing the preset with tempo specified in it (so that I excluded MIDI tempo), but the pattern seems to not hold up with the click track as it gets out of sync over time.
        I run in-ears and have a click track in my mix, so the issue is pretty noticeable.
        I don’t know if someone already experienced this, but I need to solve it ASAP.
      • #148428
        gkellum
          The Harpeggiator will sync to MIDI clock, and if you turn off the pitch stuff in Harpeggiator, it will work as a slicer as well.  You might want to give that algorithm a try.
          Here's a demo video of the Harpeggiator:
        • #148430
            Euji wrote:
            … I need the trem to work as a “slicer”, set at 1/16 note …
            I have a number of slicer / tremolo presets uploaded in a Preset List.  Easily modifiable to your own needs.
            https://www.eventideaudio.com/community/forum/stompboxes/seq-view-50-harpeggiator-presets
