Home › Forums › Products › Stompboxes › H9 Update Error Message: Error Clearing Flash memory
October 31, 2013 at 4:43 am #111175
I have tried to update my H9 a handful of times and keep getting the same error message. There is an error clearing flash memory and it also says that the stompbox did not respond correctly after 5 failed attempts.
Every time my H( has frozen with the letter A lit on the H9 screen. I then have to unplug the power supply to get it working again.
I tried the update clear by holding the hotbutton when powering up. That did nothing to help.
What am i missing?
October 31, 2013 at 3:40 pm #124965
You should probably contact support@eventide.com, giving the FULL EXACT TEXT of all error messages.
October 31, 2013 at 4:39 pm #124966
Ok. Thanks man.
November 25, 2014 at 7:01 pm #127032
I just started a new thread for this same thing. Did you get the issue resolved?
November 25, 2014 at 7:34 pm #127033
Indidog:
Different users can have different problems updating their devices. As Nick mentioned above, it would be best for you to send an email to support@eventide.com. We might recommend for example that you update the software that's responsible for installing updates, and we'll need to be communicating with you via email to send you that.
