H9 with expression pedal and 3-button possible?
Home › Forums › Products › Stompboxes › H9 with expression pedal and 3-button possible?
Viewing 3 reply threads
    • #114459
      Boynigel
        i’d love to be able to use a 3-way foot switch simultaneously with an expression pedal.  is there any workaround that would allow these two to work together?  right now i’m using an expression pedal with a footswitch that only lets me scroll in one direction which is a huge compromise.
        if i can’t use a 3-way simultaneously with an expression pedal, could i use the expression pedal in combination with say, a Tech 21 MIDI Mouse which is essentially a 3-way, minus the hot button?
        i simply can’t navigate my presets efficiently with single-direction scrolling, and i don’t want to give up the expression pedal to gain preset scrolling efficiency that comes with a 3-way foot switch.
        any other alternatives i haven’t thought of?
      • #147650
          The H9 has a combined AUX/EXP input, which limits you to either 3 switches or a pedal and one switch.
          If (as you do) want more that this, I'd recommend MIDI switches or pedals.
          • #147652
            Boynigel
              So I can keep my existing expression pedal and just add a midi switcher for scrolling?
          • #147668
            camn
              yup. I use a Disaster Are DMC-3XL midi controller, for example.
            • #147682
              br193
                how can the controller on the eventide site have two switches and one exp input? i would like to build something like that (not so overpriced)
                • #147684
                  gkellum
                    You mean the Barn3 OX9? You can either use the two switches without an expression pedal or you can use one switch with an expression pedal.
