H90 – 2 mono IN / 2 stereo OUT
Home › Forums › Products › Stompboxes › H90 – 2 mono IN / 2 stereo OUT
Viewing 3 reply threads
    • #195762
      lukethemore
        Hi there !
        I always used my H90 with a simple 1 IN / 1 OUT … easy setup.
        Now, I would like to use the H90 as “dual FX” with 2 separate inputs.
        Something like:
        – IN 1 (I would like to feed the FX A) > would like to use OUT 1/2
        – IN 2 (I would like to feed the FX B) > would like to use OUT 3/4
        I tried … but I can’t find the way to do that …
        Can someone help me ?
      • #195763
        Hermetech
          I think it’s as simple as using IN 3 (for OUT 3/4) instead of IN 2.
        • #195764
          joecozzi
            Hello lukethemore,
            Have you considered Dual routing mode? The H90 would act as two independent stereo effects processors where In1 > Out 1&2 would be Path A and In 3 > Out 3&4 would be Path B. On a program basis, you can place both presets on Path A, both on B, or one on each. Plus, when they are both on the same path they can run in series or parallel.
            This video gives an in depth explanation of Dual routing mode: https://youtu.be/0G_WtfUatSc
          • #195767
            lukethemore
              Thank you for your answers !
              Finally … it works !
              I missed the option “Global > Routing > Dual” … I was looking for it in the editor, but I had to switch this option on the pedal !
              Thanks folks !
