Home › Forums › Products › Stompboxes › H90: ALG Idea:VCF/VCA w/ dedicated Attack Release Envelopes
- This topic has 2 replies, 2 voices, and was last updated 1 month, 2 weeks ago by
monkeejuice25.
September 14, 2026 at 10:30 am #200652
Hello fellow H90 zealots,
First of all, allow me to say that I am very impressed with the Polysynth alg. It does seem to capture and even improve on the character / features of the GR300 and I find it to be especially capable when stacking two Polysynth ALGS in parallel. The filter is pretty great and the tracking with the SIFT tech is just superb.
In trying to keep this short, I will just go ahead throw this idea out there to see what sticks.
As far as non-GR guitar textures go, Attack/Release envelopes are pretty great for creating those synth pad swells. However, I don’t see a way to achieve this with just the incoming source tone. If I am missing something in the ALG menu, stop here and please point mein the right direction…
Otherwise, here is what I can imagine:
An algorhithm that has filter and amplifier that are controlled by their own attack/release envelopes.
Here are some specs that could make it quite useful:
–Filter multimode: LP/BP/HP/Notch w/ multiple pole options (At least 12dB and 24dB)
-Resonance capable of self oscillation.
-Bipolar Env Intensity
-Dedicated Cutoff (Unlike ModFilter)
–The VCF and VCA Mod options should both include their own dedicated Attack/Release envelopes.
-The Attack stage could be a set amount that that switches to the Release stage if the incoming source falls below the signal threshold.
-The Release stage could employ a delay module(with it’s own slow attack module on the front end to smoothly extend the release time to the user determined amount.
(Similar to doing volume swells into a delay pedal with some regen but maybe with some granular interpolation between repeats)There would be a great deal of utility for something like this being that there does not appear to be a filter with the conventional parameters in the Oberheim/Moog vein of thought. And the A/R envelope could be useful for ‘Slow Gear’ effects as well as driving the Polysynth ALG on the front end or down stream in a multitude of ways.
Again, stop me if I am being too daft to look in the right place in the ALG list..
This is all just pie in the sky but, until the H9000 graces my studio, this will have to serve as my wishlist post.
Thanks to Eventide,
W. -
September 14, 2026 at 3:24 pm #200673
I really like your ideas. There was some talk at one point about global controllers, assignable to parameters, such as an LFO or two. I say a step sequencer with smoothing & one-shot (or X repetition) capability covers almost everything. ADSRs, wavetable shapes, etc.
No idea the difficulties involved to implement that. Your concept seems more practical, contained inside an algorithm package. That excellent PolySynth envelope follower needs more targets. Maintain the EF, use its detection trigger, split & reshape that envelope before branching off to amplitude, cutoff, resonance (and dare I add pitch shifting).
The same basic concepts are there in HotSawz, in a limited sense. As for existing general control over envelope, there are a few options you can try. With a few threads on this forum about the upsides & downsides in each one.
DynaVerb / Omnipressor. UltraTap / Chop Machine, using the Swell & Trigger selections. TremoloPan, using an Envelope Shape. (The Modulation ADSRs have a short, fixed profile). Ducked Delay at zero delay times. Might have missed some. Not complete solutions, but situationally useful. They can be tricky to adjust, and find your way around the core limitations.
September 16, 2026 at 3:55 pm #200827
Giving the Ultratap Alg another look, it seems as though it has the components to extend the note after the source has ceased by a smooth and predictable amount. This could drive an envelope follower to drive a ‘VCF/VCA’…
