H90 Control : How to Edit Presets
Home › Forums › Products › Stompboxes › H90 Control : How to Edit Presets
    • #168813
      davidjohndowling
        I don’t see an obvious way to change the A/B Presets within a Program using H90 Control. Can someone detail this for me?
      • #168826
        joecozzi
          – Open up H90 Control make sure you’re in the “Edit” window, the default.
          – On the bottom right of the window, click on Preset Library.
          – At the top of the screen you can select which preset, A or B, to work with.
          – Because all presets are listed in alphanumerical order, you can narrow your search by effect type and/or by algorithm.
          – Simply clicking on a preset will load it into the selected slot, A or B.
