H90 Control: How to save program to another playlist?
Home Forums Products Stompboxes H90 Control: How to save program to another playlist?
    • #168712
      emarinko
        I can’t seem to find how to save or copy a program from one playlist to another in the H90 Control app.    When you click the save icon, it only lets you pick a different position from the current list.     Outside of that menu, if you select another playlist from the dropdown above the programs list it immediately changes the current program and loses your changes without saving.
        It seems odd that the desktop editor wouldn’t be able to do this so I’m wondering if I’m just missing something?      You can select a different playlist while saving from the unit itself… but the same option is missing from the flyout menu in H90 Control.
      • #168717
        apalazzolo
          From memory:
          You can right click copy a program, then select the target list on the top left of the screen, and then right click paste the program in the desired  location.
          Also, if you select the target list on the top left of the screen and then select PROGRAM on the top middle of the screen, you can drag and drop programs into the target list on the left.  You may want to sort the programs on the main screen first … maybe by program list name.
          Good luck!
        • #168892
          emarinko
            That did it!   Thanks a bunch!
