H90-digital hash on the output
Home › Forums › Products › Stompboxes › H90-digital hash on the output
Viewing 5 reply threads
    • #168026
      zambiland
        I hooked up my H90 in my home studio going 1/4″ (with and without a Radial isolation box) and XLR via a passive DI to a Metric Halo ULN-8. No matter how I do it, with ground lifts or not, I get a digital hash sound on the output at about -45-50db. It’s been dead quiet for the most part.
        Any ideas?
      • #168027
        joecozzi
          Do you have USB hooked to your computer as well? Depending on your setup, this may cause a ground loop.
        • #168028
          zambiland
            I’ve tried it both ways. No difference
          • #168029
            joecozzi
              What else do you have connected to the H90?
            • #168030
              RikjCarty
                Try plugging everything into the same leg (i.e everything on the same power source/Plug… including computer, as a starting point). For some reason control apps via USB are Notorious between computer connection and isolated switching supplies. With 2 prong supplies… you CAN reverse the polarity of the AC plug. In some low cost, 2 prong (US) switchers, this changes the ref ground.
                Best!
              • #168031
                zambiland
                  I’ve made sure it’s plugged into the same leg as everything else (I have a dedicated circuit for audio). I have switched power supplies. I’m going to do some more experiments, including plugging it into a battery powered headphone amp.
