H90 EXP/CTL input specifications
Home › Forums › Products › Stompboxes › H90 EXP/CTL input specifications
    • #168129
      fonitronik
        I was not able to find the correct answer in the manual or here inthe forum.
        Assuming that the CTL inputs expect 0-5V. However, my SERGE modular can easily output control voltages of -12V to +12V.
        How are the H90 EXP/CTL inputs protected against over- (or under-) voltage? Are they at all?
      • #168188
          That is correct, the H90 will respond in the range of 0-5V. It has adequate circuit protection to make standard synth ranges safe.
        • #168205
          fonitronik
            By standard synth range you ean +12V/COM/-12V, I assume? That is good to know.
            The input impedance of these inputs is 100k?
            Thank you.
