H90 Expression Calibration seems a off
Home › Forums › Products › Stompboxes › H90 Expression Calibration seems a off
Viewing 5 reply threads
    • #188908
      chapoteaukatz
        Hello everyone,
        First couple of days digging into the H90 and I’m attempting to do two things on my current program. First, I’d like to map the pitch on an octaver to raise an octave when I hit the external footswitch (in exp 1). Something strange keeps happening when I choose the amount on the pedal though – no matter what pitch I set the external switch to change the pitch to, it will always go to another pitch. And it isn’t just one off every time – sometimes it’s a few semitones, sometimes it’s 1… and the full range of the parameter will be right on. I am using a TRS cable and have tried with two different foot switch devices to confirm the issue is not with the footswitch.
        Secondly, I’m trying to use my expression pedal (in exp 2) to control the speed of the loop to sweep to a fourth up (around 100-136). However, I don’t seem to be able to select expression 2 to control that parameter – only expression 1 shows up.
        I have tried calibrating but it doesn’t seem to fix either issue – it also just says “off” after I complete it. Is there something I’m doing wrong here? Any help would be greatly appreciated, thanks so much!
      • #188909
        joecozzi
          I’m having a similar experience. Let me discuss with developers and get back to you. For the time being, the way around this is mapping your aux switch to one of the three available HotSwitches. Program that HotSwitch to go between the values you need. That works for me. Directly mapping the aux to the parameter causes the issue you’ve raised.
          Secondly, I’m trying to use my expression pedal (in exp 2) to control the speed of the loop to sweep to a fourth up (around 100-136). However, I don’t seem to be able to select expression 2 to control that parameter – only expression 1 shows up. I have tried calibrating but it doesn’t seem to fix either issue – it also just says “off” after I complete it. Is there something I’m doing wrong here? Any help would be greatly appreciated, thanks so much!
          When you map the expression pedal to the Play Speed parameter on the Parameter Mapping page, can you turn quick knob #3 to show you Pedal #2? It does seem to take one whole turn of the knob to register.
          • #190880
            chapoteaukatz
              Hello Joe! Any chance the aux switch thing will be able to be rectified in a future update?
            • #190887
                We plan on fixing this issue in a future update but I cannot provide a timeline for when this will be available. I’ll reach out to you once we have something ready.
                Sorry for the inconvenience.
            • #188915
              chapoteaukatz
                Hey Joe! Thanks for the quick reply.
                You’re right, I just needed to turn soft knob three a bit further than I was expecting. Working great now!
                I’ll try the hot switch work around. Appreciate it!
              • #188919
                chapoteaukatz
                  One more question – is there a way to map the functions of the looper algo to external foot switches? Because of where my H90 is located, this would be much more convenient for me – however, I can’t figure out a way to do it as those functions don’t show up as parameters. Any help would be greatly appreciated. Thanks Joe!
                • #188920
                  joecozzi
                    Yes. Looper functions can be mapped from Perform mode. Once you press the PERFORM knob on a Program that incorporates the Looper algorithm, press & hold the LED Button (A or B) that corresponds to the position of the Looper. Immediately, you will enter the Performance Parameter Mapping menu where you’ll be able to find the looper functions with quick knob 1 and make assignments to any external aux switches(s) with quick knob 2.
                    Something to note: if you have the latest firmware, Eventide has added a dedicated looper control page in Perform mode. Consecutive presses of the PERFORM knob will get you to the third page of control already mapped to RECORD, PLAY, and STOP. You can map any additional looper controls on any of the other Peform pages or aux switch as outlined above.
                    • #188941
                      chapoteaukatz
                        All of that works, thanks Joe!
                        Last question; am I right in thinking that the only way to map an aux switch to a hot switch is globally, in the system menu? IE, I would need to have them like that across all patches?
                      • #188942
                        joecozzi
                          Not necessarily. The only functions that can be mapped globally are the ones found on this list: https://cdn.eventideaudio.com/manuals/h90/1.8.6/content/appendix/global.html; they correspond to Global-Pedal Control and MIDI-Global Control functions. Some other Perform Mode options can only be mapped on a Program basis, like the looper functions you asked about previously.
                        • #188943
                          chapoteaukatz
                            OK! Still wrapping my head around it. Appreciate your quick responses.
                        • #195469
                          unfunfionn
                            Hi there,
                            I was wondering if there’s been an update on this? I’m still experiencing what I think is the same issue, but it’s not just limited to an expression pedal. The issue is the same with the HotKnobs themselves. In my case, I’m trying to control the Shift parameters in the Polyphony algorithm with either an expression pedal or HotKnob A. No matter what I do, it doesn’t set the correct minimum value. It is always one value too high or too low, i.e. when I want to set it as unison it saves -m2 or +m2 instead. This basically negates everything I’m trying to achieve.
                            Best,
                            Fionn
