H90 Harmonizer – feeding MIDI notes
Home Forums Products Stompboxes H90 Harmonizer – feeding MIDI notes
    • #176131
      jjhassel
      I would like to know if there is a way to feed MIDI notes to the H90, so that the Harmonizer (Pitch Effect) generates those same MIDI notes. In this specific case, sending MIDI chords out of a keyboard
    • #176132
      No direct support for MIDI Note input.  There are methods for converting MIDI Notes to the appropriate MIDI CC values that the H90 expects to ‘see’, but it’s not plug ‘n’ play.
      It will depend on your current setup, and probably some additional hardware / software.  Of course, you will be limited to the pitch-shift range in any given algorithm.  Usually +/- 2 octaves; sometimes more, sometimes less.
