Home › Forums › Products › Stompboxes › H90 insert – any AD/DA conversion
- This topic has 5 replies, 4 voices, and was last updated 1 year, 10 months ago by
rantanplan747.
May 4, 2024 at 11:47 am #182131
With the new feature to keep the insert active even with the preset off, a true wet/dry rig using the H90 as the split is now feasable.
My question is, with the preset off (insert still active) does the insert go through any ad/da conversion? I have tried it, and with the H90 in true bypass (relay) mode, the insert sounds the same (with the preset on or bypassed)
Does anybody know if there us any ad/da conversion happening? It doesn’t sound like it.
May 4, 2024 at 8:43 pm #182179
Update. Signal still goes through buffered bypass and not relay, so conversion is present in insert.
May 5, 2024 at 3:34 am #182215
Yeah, for sure it still goes through ADDA cos I can still hear/feel the latency, unfortunately.
May 9, 2024 at 6:19 am #182543
How much latency do inserts add exactly? Not including the inserted pedal!
In the manual it says Input -> Parallel -> Output = 3.8ms, Input -> Series -> Output = 4.5ms.
Does that mean that each Preset takes 0.7ms (in series) and therefore an empty lane, meaning just ADDA takes 3.1ms? Calculated like this: A/D=1.55ms + Preset A=0.7ms + Preset B=0.7ms + D/A=1.55ms
If that is the case, I guess using 1 insert would add 3.1ms. But would a second insert then add another 3.1ms when routed in series? Or does it stay at 3.1ms regardless?
May 9, 2024 at 10:31 am #182567
Each insert adds 3.8 ms of latency, plus any additional latency compensation specified in the Insert setting. Two Inserts in series will add about 7.6 ms.
May 9, 2024 at 11:25 am #182571
Not the answer I wanted to hear but thanks for the clarification!
