H90 Insert 1 & insert 2 Act/Byp(M)
Home › Forums › Products › Stompboxes › H90 Insert 1 & insert 2 Act/Byp(M)
Viewing 0 reply threads
    • #206923
      Kubicixfactor
        Any view on whether Act/Byp(M) will be implemented for inserts 1 & 2? I’ve come to a standstill trying to get an external midi controller to switch insert 1 and insert 2 on/off – it works for the first press (switches on) and second press (switches off) then it needs two presses to switch on and off. Impossible to use because the H90 is located behind me when playing so I can’t easily see whether the insert is active or not.
        I had the same problem with switch A and B when setting up the controller and resolved this with setting the MIDI CC for Act/Byp(M). Midi controller is a Graviton M2.
