Home › Forums › Products › Stompboxes › H90 Insert/Dry Out Mix Control with W/D/W
- This topic has 3 replies, 3 voices, and was last updated 3 weeks, 4 days ago by
jacobdrab.
September 16, 2026 at 10:53 pm #200871
Hi all,
I’ve been enjoying the H90 for several years now and recently started using it with a more elaborate amp + ableton rig — effectively a wet/dry/wet.
In a typical mono or stereo context I often use an expression pedal to control the program mix parameter and really enjoy the ability to make any given program ‘fully wet’ when toe down with no dry signal audible.
Unfortunately (unless I have been stupidly missing something), this ability gets lost when I tap a ‘dry out’ from an insert and run the unit or given program in ‘kill dry’ for a stereo wet out.
Because I can’t map the insert send level to the expression pedal (I’d map it inverted alongside the 0-100% program mix parameter), the dry out is always in.
Is there perhaps a way to achieve this presently that I haven’t yet thought of?
If not, are there any plans to implement such a feature soon?
For all the flexible and amazing parameter mapping the H90 has to offer it would be nice to have a little more control over the routing and I/O.
I could see mappable insert mix being super useful as well in order to gradually blend in external effects.
If anyone has any advice on how to achieve the above, I’d be super interested to hear any insights!
Thank you all.
September 17, 2026 at 1:18 am #200872
Hear hear!
I’ve been poking at Eventide since I bought my H90 years ago on the ability to map send/return parameters to midi / expressionWeird that they left some parameters out of mapping at all actually!
September 17, 2026 at 1:55 am #200885
Same here, I have a Strymon BigskyMX as Insert 1 Stereo in parallel and when I mute Insert 1, I get the clean signal added to the mix. It should be muted.
September 18, 2026 at 10:29 pm #201729
Glad to hear this seems to be a widely requested feature.
I’d love to see all the insert parameters (mix, bypass, I/O levels, etc) mappable as well as some global control over insert routing.
I frequently find myself in sessions tapping a dry out to an amp and running the H90 stereo wet DI — currently I’d have to copy all my presets regularly (every time they’re updated/new ones are made) and manually alter them for a wet/dry setup.
Since we already have a global kill dry, it would be amazing to get a global insert setting as well, which could also be set per program/preset (like kill dry).
