H90 level issues
Home › Forums › Products › Stompboxes › H90 level issues
    • #183145
      maxolla
        I’m using the H90 in the effects loop of my Fender super sonic and when I engage the effect there is an approximate 9db boost in signal.  When I depress and disengage the the level returns to normal.  I decreased the input and output level on the particular algo and it worked fine.  I’m wondering if there is a global setting for this mismatched impedance issue.
        thanks,
        Max
      • #183146
        shawcunningham
          Have you checked to see if your H90 inputs / outputs are set to line level or instrument level?   Are those mismatched?
        • #183647
          mjahoger
            Also, please be aware that there is a volume bump when you run effects in parallel and have either one disengaged.
            • #188358
              Dierblack
              Blocked
                You are absolutely right.
