H90 – MIDI PC# offset question….
Home Forums Products Stompboxes H90 – MIDI PC# offset question….
    • #167467
      RikjCarty
        When Sending MIDI PC# to H90… the Program number in the H90 is offset by -1. This would indicate that the program numbers on the H90 start at Zero as opposed to 1.
        I must send PC# 5 to select PROGRAM 4 on the H90. Is there anyway to midi map PROGRAM CHANGE numbers?
        Looked through SYSTEM page in H90 Control… Didn’t see any way to MIDI MAP program numbers or correct for this offset.
        Thanx in advance!
      • #167475
          From an earlier reply by Eventide:
          “The H90 sends and receives PC messages using PC numbers 1-99 (ignoring 0). Depending on the other device, this may offset the PC numbers by 1. We plan on adding a feature to offset the numbers on the H90 to match up with other devices.”
        • #167515
          RikjCarty
            That Answers that… Thanx Brock!
