H90 MIDI Program Changes
Home › Forums › Products › Stompboxes › H90 MIDI Program Changes
    • #166788
      MarMar84
        Loving the sounds so far! Kind of lost on MIDI. How do you use midi to load a program? EG How would I use MIDI to engage the program in USER2-BANK01-01? How would I go about bypassing and engaging both sides? I look forward to a deeper dive into MIDI.
        thanks!
      • #166789
          System – MIDI:  Select a matching MIDI Channel.  Output to THRU.
          System – Global:  Default Playlist to USER 2.  Send Program Change 01.
          H90 sends / receives MIDI PC 1-99.  3 Programs per Bank.  99 Programs per Playlist.
          Perform Mode:  P(rogram) Active / Bypass via left switch, or MIDI CC.
          • #166792
            MarMar84
              thank you so much!
