H90 stereo effects loop
Home › Forums › Products › Stompboxes › H90 stereo effects loop
    • #168690
      MN246
        Hello, I have a question regarding the inputs and outputs.  When setting up a stereo effects loop, the manual says to use input 3/4 and output 3/4.  Does it matter between 3 and 4 which is left and which is right?
      • #168691
        joecozzi
          Technically, no, but it’s most common for 3 to be LEFT and 4 to be RIGHT. Your choice though.
        • #168692
          MN246
            Thanks. I’ll connect it as you suggested is typical.
