H90 Thru vs Bypass
Home Forums Products Stompboxes H90 Thru vs Bypass
    • #166840
      gas hed
        Is there a difference?  If I’m only using 1 effect should I bypass the other or just leave it alone as a thru?
        Bypass
      • #166844
          In this case, Bypass simply defeats your In and Out Gain settings.  A utility Thru is always a Thru.  On or Off would be the same, at the default Gain settings of 0.0 dB.  I suppose you could target the Bypass toggle as a solo boost, with Gain value adjustments, or use it for gain-staging with along with a problematic effect.
