Dear Eventide Support Team,
I’m a happy owner of both the H90 and the Blackhole. Congratulations to your engineers and the whole team — your gear is amazing!
I’m currently using my H90 in Dual Routing mode and am very happy with it.
I’m now considering purchasing a small tube combo (either a Harley Benton TUBE5 Celestion or a TUBE15 Celestion) to use as a wet amp in a wet/dry setup, following the configuration shown in the attached screenshot from your H90 manual.
I also own a TC Electronic Sentry noise gate, which I’d like to use to control noise from the crunch and lead channels of my Hughes & Kettner TubeMeister Deluxe 40 when needed.
Would the following wiring configuration work with the H90, or would you recommend an alternative?
Guitar → Sentry Input
Sentry Send → H90 Input 1
H90 Output 3 → H&K guitar input
H90 Output 1 → Harley Benton input
H&K FX Send → Sentry Return
Sentry Output → H&K FX Return
I’d also like to keep my Xotic EP Booster in the H&K’s FX loop. Would this be compatible with the proposed setup?
Thank you for your time and help. I look forward to hearing your recommendations.
Have a great week!
Cheers,
Emanuel
You must be
logged in to view attached files.
