H90 with Switcher, Mono or Stereo
Home › Forums › Products › Stompboxes › H90 with Switcher, Mono or Stereo
    • #183420
      nicoesp17
        Hello! I’ve been using the H9 for years and I’d like to upgrade to the H90, of course.
        I use an Atom switcher from Atom.
        Is it possible to use the H90 as follows:
        In/Out 1 to Loop 1 (for modulation effects, for example) in Mono
        In/Out 3&4 to Loop 6 or after the switcher (for delays and reverb) in Stereo.
        Or do I have to have everything in Stereo?
        Thank you in advance for your response!
      • #183430
          Yes, you can use the H90 this way. Using Dual Mode allows you to have a different preset on Path 1 or 2, which correspond to inputs/outputs 1-2 and 3-4. You can use either path in mono or stereo.
          Let me know if you have any other questions.
