H90 with two Instruments?
Home › Forums › Products › Stompboxes › H90 with two Instruments?
Viewing 3 reply threads
    • #194288
      eventandi
        Hello, is it possible to use a program simultaneously with two instruments?
        Something like:
        Instrument1 -> Input1 -> output1
        Instrument2 -> Input2 -> output2
        Best regards, Andi
      • #194289
        joecozzi
          Hello Andi,
          Yes, the H90 can certainly process two instruments at once. This is best done in the Dual routing mode where Path 1 flows from I/O 1 and Path 2 flows from I/O 3. For a deep explanation and setup I recommend this video:
          https://youtu.be/0G_WtfUatSc
          You can go directly to the 4:25 mark for a diagram of how two instruments get connected.
        • #194290
          eventandi
            thank you for the quick response.
            Can I change the input for an existing program from I/O 1 to I/O 3 without dual mode?
          • #194291
            joecozzi
              No, because I/O 3 is used for connecting an insert effect in the default mode, which is Insert mode. In this configuration, only In 1 acts as the main input of the signal chain.
