As I previously announced I’ve been working hard over these last few weeks to update the H9000 Preset tool to fix a few bugs, and to extend its functionality to support chain support of custom algorithms.
Decoding the chain format led me down a deep, deep rabbit hole of nested Russian dolls, hence the name change.
I’ve also added an Algorithm Map tool on the preferences tab, and if you take the time to fill in the ID and exact name of your custom algorithms for you H9000, this tool will make a guess at the algorithm numbers, to hopefully save a bit of time if you use this tool a lot.
This tool will allow you to import the chains that ship with the Dynamic Send algorithm and the Genesis Collection without building them yourselves.
This tool is available for free to support algorithm developers and end users at https://godlike.com.au/index.php?id=479
I’ve got some commission work to finish off and then I’ll be back to algorithm development. As always I’m available for 1 on 1 Zoom or Teams sessions to help with configuration and use of your H9000. You can make bookings at https://buymeacoffee.com/godlikeprod/e/18240
